1992 300sl strange sound
muso58
on start up i'm getting a sound like a compressor .it seems to be coming from right front of engine .it goes off after a few minutes on idle .is this normal ?
thanks for looking
thanks for looking
Its normal to make a sucking noise when warming up,its the cold start device, do you mean a chugging noise, always hard to describe.
Malcolm
rajinder_1
Midlands
i think the cars have a air injector, this is normal it would explain the noise. it adds extra air into the engine, i think its something to do with the co levels, i had a prob with mine secondary air injector but it turmned out to be some pipes not connected as the cel light used to come on...
If your not getting the noise constantly i think u will be fine...
Raj
M
muso58
hi it sounds like a truck air compressor running light
Steve
Ian B Walker
Lancashire
300td
Its normal on the 3ltr and over engines. It is an air compressor which injects air into the exhaust when the engine starts so that the unburnt fuel does not ruin your cat. It runs for about 5 mins then cuts out.
