Hi all. New to this. Picked up a 300sl with 40k. AC not working so just inquiring if anybody could point me in the right direction as to how to diagnose the problem myself. Thanks!
Most common cause of AC failure is low gas. That would be the first thing I would have checked.
Second and third most common causes of failure are a bad compressor (lack of use dries out the seals allowing gas to escape) or knackered condenser (salt from roads corrodes them allowing gas to escape).
If it's not been used for a while you should replace the drier as well.
Most likely the gas has all leaked out, could be a failed condenser - quite common - rather than just throwing bits at it worth finding a decent local AC specialist - (not someone who's had 10 mins instruction on an automatic machine) and getting them to diagnose, leak test.
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
