1993 W124 E Wet Electric Window Controls
tjamesbo
Sutton Coldfield, West Midlands
1999 CLK430, 2007 VITO 3.0V6 , W124's (1994 320TE , 1993 220TE ) , 07 2.5 X-Type
Oh Dear The car interior got a good soaking in Last Nights Thunderstorm as I had left both Front Passenger Windows Open. This was followed by a trip home with My Window and the sunroof opening all by themselves presumably as water in the switch closed the circuits. Everything now works as it should except the Passenger Front Electric Window which will not go up At the moment I am hoping that with a bit more drying out time it will suddenly work. But am worried that the others now work and it still doesn't . I can hear a switching noise away from the switch if the switch is pressed but no window Movement. So getting prepared for the worst i thought how will i check if something has Gone . Is there a relay between switch and the window motor ? I suppose i should start with checking the switch in the centre console ??? then remove the door trim and check the motor I presume they are all on the same fuse ?
