Arv
Hello,
1994 C280 Consistent Engine Cutoff after 20+ mins at any speed & idle
& Crank No Start after that till car cools overnight.
Warm Engine "Crank NO Start"
NO Engine Light on.
When "Crank No Start" happens,
1. Tested Fuel Relays on the table by applying voltage & they work as expected.
2. Also tested by installing both relays back on the car and having someone crank while I was
hearing the click and feeling the click by putting my hand on BOTH Green relays,
one in fuse box and one in the trunk.
3. Tested the Fuel Pump also by having someone crank and I went under the car
to hear & feel the pump running.
4. Also tested that fuel is reaching injectors at the Schrader Valve by slightly
pushing the pin of Schrader Valve down (like we release bicycle or car tire air)
and watching the fuel spray out instantly.
5. Haven't tested the pressure with gauge or a syringe test yet by removing
fuel rail and also watching out for non-continuous fuel spray.
2 yrs ago, I had replaced Crankshft and Camshaft Position Sensors.
Is this a sure shot case of Leaky Fuel Injector(s) ??
Help is very much appreciated.
Thank you,
Arv.
NO Engine Light on.
Thank you,
Arv.
