- Thread Starter
- Thread starter
- #21
Thank you all for all your help. Finally I found the clog. The Bars Heavy Duty Stop Leak with pallets had clogged the 5mm inner diametered upper overflow pipe going from the waterpump nipple to the expansion tank bottle. It had clogged at the entrance of the expansion tank. Cut out the hose end and fixed the problem. Because of this clog of upper overflow hose, I kept getting coolent bubbling and overflowing from the coolent tank cap since pressure was building up in the system which also caused the plastic tank of the radiator to blow up.
Also, did the combustion test to find if the head gasket was gone, and the luck was on my side and I didn't get any exhaust gases leaking into the coolent. So I am really saved from having to do head gasket job.
Also installed a new radiator which I could purchase for $158 and I am good to go.
Thank you all for your help. Very appreciated.
Arv.
Arv.
