It all started about 3 weeks ago when the car had done a hot run, slowed down for a roundabout. When pulling onto the roundabout, the car revs started surging as though hunting. The ASR warning light also came on. Stopped the car and restarted and it all looked fine. Driving at 40mph, it started accelerating and then surging. Called it a day and was towed home by the AA. When the AA man arrived, when starting the car, it was starting right up to the 3,500rpm rev limiter in park.
Feeling this was a job for the specialists, the car went to the local dealer who have replaced the throttle body (£600+fitting!) and the OVP relay. The car now appears fine but when starting it, it revs up to and sometimes over 2000rpm (even when warm).
If you blip the throttle when starting the car, the idle can oscillate for 30 seconds hunting between 1700-1800rpm and the revs can take a while to drop from 1500rpm to 750rpm after this oscillation period. Any ideas, or advice of where to send the car if the local dealer can't solve the problem?
Putting the car on the diagnostic equipment showed no problems but showed that the throttle butterfly angle was remaining at 4.8 degrees during the oscillations and would remain at 2 degrees or so before dropping to the usual 0.7degrees (=750rpm). This is the only fault on the car (it drives perfectly now) - could this be a sensor? Or an Idle Control Valve? There was a stored fault of a problem with an O2 sensor (Clearly a recent problem) but this wasn't recurring on the diagnostic computer when the car was doing this.
