1994 S280 Rear side window problem + air/con recharge?
Status
Not open for further replies.
pete's S280
Hi, anybody help? my rear side window has just dissapeared to the bottom of the door, and fallen of the channel. My other rear side window just clicks. also my air/con needs a recharge. I live in Southampton any help with where to go would be great without being to expensive? I tried to remove the rear door panel but although all the door clips seemed to come off there seemed to be one centre fixing near the door handle that would not come free! Any technical people out there with info?
thanks Pete
guydewdney
Tring, Herts
www.atct.co.uk
P
pete's S280
Rear window problem W140
Thanks for your help, I did not realise this was a common problem,
how easy is it to locate and release the centre fixing behind the wooden panel, I have already damaged slightly the right hand edge and do not want to do any more damage. the air/con is just not working what should I look at first?
Pete :cry:
guydewdney
Tring, Herts
www.atct.co.uk
i dont know - i have two doors.... do a search on the oterh forums, this one, and mbclub.co.uk -
sorry
air con - 1) Get it checked - use this:- http://www.continentalimports.com/ser_ic40142.html
2) Get it re filled - make sure there is lubricant added!! a compressor running with no lubricant will go bang... v expensive. get dye added as well so you can find any leaks.
Status
