paininthecclass
- Mar 4, 2008
Hi my w202 c 200 has an acting up immobiliser does anyone know how to bypass it?
thanks
thanks
Welcome to the forum.
How do you know for definite that its the immobiliser playing up?
I take it that your key is a single button remote with a flip out key.
Have you tried fixing the alarm system rather than bypassing it?
Did you try your spare key?
It can be bypassed, Mercedes told me how to bypass mine, also when I called out the AA they knew from one of their tech books.
The immobiliser on this year has nothing to do with the diagnostic side of the vehicle as all it is an aftermarket Scorpion Alarm fitted to the vehicle by MB once it was in the UK.
If it was the Immobiliser at fault the engine would completely die not just go into limp home mode.
If the Immobiliser was at fault the diagnostic would,nt read any codes in the ECU at all as the immobiliser cuts the power supply to it.
I think you have an ECU problem personnally, to be completely honest i don,t think your car will even be equipped with a limp home facility because of the age. I have read posts that one of the main symptons for ECU was a restriction of engine speed.
Hi thanks, it is the transponder type, the main module has been tested by lynx and they have told me that it is the immobiliser circuit of the ecm, that is causing the fault, they cannot repair it as something has burnt out, the two cylinder problem has been rectified so just need to short the immobiliser out.Hi,
Some 202’s of that era had a transponder immobiliser system fitted. One easy way to tell if this car has it is to look at the surround of the ignition switch. If it has a raised surround to the ignition then it is the transponder type. The raised part is transponder aerial/reader coil.
It is not very clear but the fault appears to be two cyls shutting down. That is not caused by an immobiliser or limp fault. You need to look further for that issue.
The second symptom of the LED’s flashing is connected to the immobiliser but not the way the engine runs. It seems to me that you have two separate faults.
You mentioned carsoft advanced diagnostics. There is nothing advanced about carsoft. I have often seen carsoft lead a mechanic astray. I think you need to look further. The main causes of these going off two cyls are coils, coil wiring, injector wiring and ECU. Never mind the fault codes, get someone with a scope to check what is actually happening.
If you look in the passenger footwell, lift the carpet where the foot rests, remove the metal plate and you will find the imobiliser unit.
I beleive the remote and the unit are coded together.
Have a look and you may be able to by pass it.
Sounds like a plan. what does it look like
There should a steel plate bolted down by 3-4 plastic nuts in the passenger footwell,
Remove lower dash panel (phillip scews) pull the top of the carpet back and it will be there (if your car was LHD it would be where the pedals would be) fixed to the floor/firewall.
The ABS computer is there too and is silver also (mine is silver anyway).
the abs computer was not under there, just the body control module and immobiliser, now i just need to find out how to bypass itHi,
As i have said i do not have this type of immobiliser system on mine and never heard that this system was fitted to a W202 but this is where my alarm control box is fitted, so i think it would be reasonable to assume that your transponder immobiliser is fitted here.
You could try putting that pt. no. into the Inchcape Mercedes site and it may give you the item description (and price), or alternatively ring your local MB dealer asking for a price for that item ask them the items description.
Just for curiousity how many plugs/cables have you got going to it?
Did you identify the ABS computer in that location?
everyone is looking at 250+ for modules second hand, the cars not worth thatI'm sure if you buy another module and key fob from another car, it would work.
