Ron Palfrey
- Jun 6, 2005
- C280 Elegance 1994
Car has developed a light knocking noise at the offside front when travelling slowly over any road surface that is not perfectly smooth. Doesn't happen for first 10 miles or so but then starts. e.g. pulling up at a red light gets a knock as I come to a stop and the suspension compresses, then a similar knock when I pull away and the weight transfers from the front suspension. Once it starts there is a clonking over rough surfaces at low speed.
Can't feel anything through the steering, car steers fine, no vibration, just this dreaded low speed clonk.
The noise isn't noticeable at faster speeds, just at town speeds of say 30mph or less.
Anti roll bar bushes look in good condition. Bush at bottom of shock absorber looks OK too.
The usual shocker test by pushing down on front wing makes no noise when cold. However, if I pull up when the noise has started after 10 miles or more, the same test creates the clonk when I press down and when the car comes back up.
Anyone else had this problem? If so what was the solution please?
I'm off to France in a couple of weeks and I would like to sort it before I do 3000 miles in the space of a fortnight.
Many thanks in anticipation of your help / ideas,
Ron
Ron
