1997 c180-autobox
karlk
cambs
Hi, new to MB and the forum. Short story, purchased 1997 c180 elegance. 122k on the clock but near on perfect service history. The cosmetic condition is A+ and drove 350 faultless miles, however went out today and the gearbox is not changing up, stuck in gear , no lights showing and will rev right up to 4k no problem. Any ideas of where to start,
cheers
karl
roofless
w124 e220 estate
try the fluid level first the dipstick is at the rear left side of the engine
K
karlk
cambs
right, just used a 1.6mm tig welding rod as dipstick, im sure it went to the bottom of the box sump cos of the shape of the wire when removed, oil is showing a level of 50mm with the engine and box warm, engine was running for a good 15 mins and drove round the block a couple of times. I also disconnected the multiplug on the box to check for oil leaks, none at all. the plug is clean and dry, no damage to harness. Any ideas as to what to try next.
cheers
roofless
w124 e220 estate
try the maf might need a clean or replaced you might find it in the how to section
jab
I just got rid of a simler problem,get it on the computer,Mine dident show any warning lights,The fault codes came up 036 Lambda Reg, System too Rich prob causes exhaust leak, MAF sensor,Fuel presure,injecters,ecm.The other code was 056 BoschHFM/Siemens PMS [depending whats fitted] prob cause fuel pump relay-wiring.Mine went into get you home gear.in the end 8 garages and alot of high quotes later i got the car to a gear box specialist who replaced the hydrolic valves,oil-filter,£650 LATER ITS NOW OK
www.W140.co.uk&www.r129.co
