Mikesmerc
- Jul 3, 2003
- Location
- Co.Cork IRL
- 2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Hello all, the 97 E230 that I have on trial, central locking is playing up. The only doors that lock are the front ones and the boot only opens using the metal key. Checked all fuses and all seems fine. Lifted the back seat to have a look at the vacuum pump and fuses, tried pressing the key to see if the pump was working but now the remote on the key wont lock even the front doors , I also tried the spare key with the same result, the red light comes on but with no effect. Using the locking button on the dash the pump runs and locks the front doors but nothing else. Sounded like an air leak on the pump when running so I checked all pipes on the unit and they were fine. After a while I pressed the grey cover(which the pipes are connected to) down toward the pump while the dash button was pressed and all doors locked and opened. So I have now found the culprit for the back doors not locking but what has happened the remotes since I started investigating?
Also found an odd looking device near the vacuum pump, it looks like a manual device for checking the vac pipes, it has a plunger on top which you press or pull and a small pipe out of it. It is also wired up, with three wires, one to the vacuum pump and the other two dissapear under the carpet, has a mercedes benz stamped on it. Any have any ideas?
Mike
Mike
