I’ve had my C250 TD(AUTO) (67000 miles) for over five years with no major problems.
I recently had it serviced and since have had no end of problems with it starting and running poorly.
When cold it can take up to 20 seconds of cranking to get it to start which I'm sure is not doing my starter motor any good. When it does start it doesn’t sound or perform particularly well.
When on the motorway the car will sometimes only go to around 2500 rpm (70mph). Today the car held at this and then stalled when I pulled off the motorway and gave a poof of blue smoke.
Generally there appears to be a lack of power. Having had the car for so long it is certainly not performing as well as normal.
The faults are intermittent which is hampering my local garage being able to diagnose the fault.
There appears to be some air bubbles in the fuel lines to the fuel filter. I had the glow plugs changed about 1000miles ago.
Any help would be appreciated.
