Hi, Has anybody got any information on the removal of the cylinder heads on my E240? Does the timing chain have to be split? Any special tools required? I am loosing coolant and the oil filler cap is getting emulsified.
I agree with Ultymate on this, pressure test the system first. If there are no external leaks, then assume a head gasket problem. Also have you pulled out the dipstick and is there any emulsification there? The oil filler cap is not a 100 percent sign, other things can cause this.The fact that your oil cap is getting emulsified is not a sure fire sign your head gasket has failed, the cap is in a relatively cool spot on the engine and therefore prone to condensation particularly if you do a lot of short journeys so I personally would'nt strip the head on that evidence alone. You need to get your cooling system pressure tested both hot and cold. I'm not saying the gasket has'nt failed but don't strip your engine on the evidence of the emulsion on the cap alone :-?
Totally agree, do the tests first and go from there.If you are in the trade, have you done a block test on it? What colour was the fliud? If you do remove the heads, the cam sprocket bolts will have to be replaced are they are also stretch-bolts. Although I havn't read anything here yet that would convince me to remove them! Does it run bad,does it start OK, are any of the plugs a different colour? Coolant leak is more likely to be rad or something slight that you havn't noticed yet.
I agree Malcolm, but its all part of the pressure test, wet carpets ect. In any case the person doing the test should know what they are looking for (I hope)One should not forget the heater matrix that could have a slight leak, any water going under the carpets, and may not get noticed.
As Stargazerplus and Type 49 says there are no known problems on this engine,and we have not had one here.
Malcolm
P.S. Is this vehicle one of the ones prone to leaking coolant into the transmission via the cooler?
Valeo rads only affect 722.6 box in the 203,209 and 211 up to 30-09-03.
Malcolm
You can just unbolt the sprockets and remove the head easier done with the tensioner removed,do take care with that, when you do it if you want details of the tensioner just ask.
Malcolm
Hi Malcolm, could you give me more information regarding removing the tensioner & sprockets. How do you hold the sprockets in situ but still be able to remove each head? - special tools required?
Darren
