1999 c250 td front caliper identification..help!
Ad777
1999 C250 TD estate W202 engine
Hi there, my front right caliper is sticking, so initially tried breakers to get replacement. It appears that the 250 caliper are different from other c class models and not interchangeable, and are accordingly hard to find.
I have started looking for a repair kit, but seems to be multiple options.. can anyone point me in the right direction!
On my caliper, at the top it says Germany, and I think 1748P stamped below it at the bottom it has57/25/288, and 922 stamped further along does that make sense to anyone! Any input hugely appreciated.
EmilysDad
Bury Lancs
ML350
I'm sure that somewhere like Bigg Red will either be able to refurb' your calipers or supply a seal kit. There can only be a limited variation in piston/bore diameters on a brake caliper so seal kits must be available .... :confused:
A
Ad777
Thanks for that. I will give them a shout and see if they can help! Appreciated
A
Ad777
£16 for the full kit including postage! Thanks very much again, a great pointer in the right direction!
