It does vary alot depending on age, engine type and miles. If you take it to a dealer for a massive service. £700ish. If you take it to an independent you can normally half it.
As above, it does vary wildly.
But generally.
Oil and filter as normal.
Auto box fluid every 40-100k depending on who you talk to - if it's not been done yet, it should be.
Brake fluid and coolant every 2 years
Possibly the pollen filter and additional filter if it's a digital climate system.
MB's don't have timing belts so no worries there.
Not sure when the 230 needs plugs - the 240 was every 60k but I guess it would need some.
I think I'd particularly be looking for evidence of a couple of coolant changes and also brake fluid changes as jberks says. These are normally listed as extra items in the servicing schedules and a concientious owner should have had them done. Although did I note on this forum some time ago that there might be a 10 year antifreeze available? Worth asking the questions though.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
