"2" stroke oil mix
C
cyg
Anyone know about adding a small amount of two stroke oil to your deisel ?
This was a method used before winter diesel, to stop the diesel "waxing" not required or recommended these days as all of the diesel has additives added to stop this already.
mej
IoM and Languedoc
S124 1994 OM606, ditto OM605, ditto M111, W126, S211, W169
I think it is more to do with increasing the lubricity of the diesel, reduced by the agents required to bring down the sulphur content to meet current emission legislation. There have been claims of increased IP and other component wear as a result. I've been doing this (300ml per 70 l tank) on an OM 646 and an OM605 since the beginning of the year. Possible slight improvement in consumption, but could be attributable to other factors, and a possible smoother note in the engines, but could be a 'placebo' effect. No negatives though, so will probably continue.
mersum1es
Finland
+1 for lubricant effect, petrol is used for better low temperature behavior. But wouldn't use either of the with CDIs...
spock500
Milton Keynes
300TD, 1998
MB have been known to add two stroke on endurance rallies where fuel quality is not guaranteed.
As mentioned previously, it helps compensate for today's low sulphur fuels.
C
cyg
Im a fan of Redex now & then & i new about the petrol add, but this was a new one. No to CDI`s ??
I also dont buy supermarket stuff.
