mlc
- Sep 4, 2003
- Age
- 67
- Location
- South Manchester
- 2001 S320, 2003 SLK230, 1972 350SL
The first question should really be - can anyone recommend a workshop manual available for the SLK model!
Two problems - the first is that although I can trigger the alarm their is no noise, just the hazard lights flashing. Their is an item on the N/S inner wing that I assume is the alarm sounder, its correctly connected and also triggers the alarm if diconnected - any suggestions.
The second problem is the headlight washers, nothing happens if I press the dash mounted button. I have taken power to the pump and it works fine. Is the dash switch suppossed to trigger a relay somewher and if so where is it?
Any suggestions will be greatly appreciated.
Mark.
Mark.
