2000 W210 320 cdi SIERIOUS PROBLEM please help!!
Bobby Abraham
Had the car parked at the house for a few weeks took it out for a run and noticed vibrating from back wheels turned to go back home and then heard a loud bang from the back, got home and noticed that the vibrating was down to someone loosened the nuts on the back wheel, now it has a whining noise coming from the engine and loss of power.
any idea
thanks BOBBY
Will think about this one while in bed
Stu_CDX
Essex, UK
Could there be damage to the diff causing the whine and maybe not distributing power correctly so therefore loss of power into thin air?
Stu.
dave.robbo
Gloucester
2004 SLK 350 R171
Loose wheel bolts shouldn't have any effect on the engine!! The bang could have been one of the wheels hitting the bodywork?
Damage to hub/disc, causing the handbrake to stick on?
Stu_CDX
Essex, UK
Are we sure the whine is from the engine and not the back axel? Does it increase with speed and gear changes or RPM and engine tone?
Cant work this out, from the info posted. A loose wheel would not affect the diff. also its quite easy to tell if the whine is coming from the front or the rear, and when pulling or in the over run,or when revving at idle.
The bang could have been a rear brake stuck on
B
Bobby Abraham
Thanks for all the replys the noise is defo cuming from the engine (lower part, matbe part of the gearbox??) the whine is there when reving on idle and wen driving?
THANK AGAIN
DaveE320CDI
york
2004 E55 Kompressor
Hi, Check the pipe coming from the turbo to the intercooler theres a plastic part held on with spring clips sometimes these blow off, sorry to say breaking the lip off the plastic pipe, it goes with a real bang, and then off course no power due to loss of boost, cheers Dave
Parrot of Doom
Manchester
Maybe the parking brake is seized. That would certainly cause the wheels to vibrate, especially as the car has been parked up for a few weeks.
B
Bobby Abraham
Just an update still dont know what the problem is but just to add that also the car wont rev over 3000rpm hope this clicks somthing with someone .
Thanks again
BOBBY
Parrot of Doom
Manchester
They won't rev over 4k in neutral anyway.
Have you jacked the rear end up and checked everything is tight? Push and pull the wheels, check the bearings, etc? I still think you should check the parking brake.
G-a-r-y
Bristol
S211 320 CDi, SLK 200 R171.
I wonder if as well as loosening your wheels nuts they have stuck something up/in your exhaust pipe. This would make the turbo whine and give you a loss of power?
