2001 CLK200K Boot/trunk lock out
bigles
I believe I have a major battery problem on my CLK. The battery is in the boot/trunk and the emergency (mechanical) key doesn't work.
I've called out the roadside assistance guy and he tried connecting a power supply direct to the starter motor, still to no avail, can anyone help?:confused:
Aussie Nick
Melbourne...Australia
The remedy i have observed on the forum is to try to loosen the lock by lubricating the lock with Rp7 and persistence with the key. It should work after a while. If that doesnt work I would recommend that you try an industrial spray lubricant called Rostoff Ice which is used in marine applications on parts fused together by rust
B
bigles
The lock doesn't seem to be stuck, the key turns freely in the lock, but doesn't release. I've tried a lot of manipulation.
Aussie Nick
Ok .
A. Can you take the rear seats out to get to it through the cabin? I cant remember whether the CLK has an entry to the boot from the cabin.
B. Have you got access to a high pressure air compressor with the thin pencil nozzle?
B
bigles
Thanks Aussie Nick,
Theres no easy way to get through to the rear compartment, without wrecking the seats.
No I don have an HP compressor.
At the moment I'm leaving the car and hopefully enough charge will build up to release the lid if I leave it alone for a few hours. It opened fine earlier today, just died when I tried to start the damn thing.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Sorry to be obvious but have you pressed the button in on the boot.
jib
B
bigles
Yes I tried pushing in the button and all combinations of holding the internal boot release and external too. I am stumped
B
bigles
I left it for around 2 hours and the remote worked, I've now removed the lock and am getting the RAC to look at the battery/electrical problem. Thanks for all your help people, I'll report on the root cause of this electrical problem when its resolved.
If you are having problems opening the boot lid can I suggest you leave the car with all electrics off and try again in a few hours, enough time for enough charge to return to the battery. I also noted that when I pressed the release on the remote it took a couple of seconds for the lid to open, so pressing the button repeatedly may not he:)lp.
drivinggod09
north wales
i have had a problem getting into the boot when i disconnected the batt what you need to do is connect a power pack to the positive terminal under the bonnet on the right hand side there is a black plastiv cover over it then connect the negative up as you would jump start then you can open the boot i had to call the aa out and thats what he did good luck
