Alongwayaway
- Jun 26, 2023
- W168 2001 A170
Hello,
I'm looking for some advice as it's my first MB, I usually play with BMW's and Land Rovers.
ABS/BAS orange light is on - I've deleted all the fault codes, drove for a week and rescanned, and the only fault code stored is for the right front ABS sensor. I've replaced the sensor, tried to calibrate the steering angle sensor, and the light won't go out.
I've tested:
Original ABS sensor ( tested ok )
New ABS sensor ( tested ok too )
Steering angle sensor
Brake switch
Gear selector
I'm now running out of ideas - has anyone got a wiring diagram for the ABS system so I can test for continuity of cables from the ECU multiplug down to the sensor, or any other ideas as to what could be causing the problem?
I've tested:
Brake switch
Gear selector
