2002 C-200K with loads of faults
Status
Not open for further replies.
tony0710
East London
www.leytonfootclinic.com
Hi all
I bought a C200K last year - 07/10/02, within the year I have had a list of problems, can anyone tell me if another C200k has experienced these faults and what was done!! The car has been seen to and as most of the faults are intermittent, and do NOT occur with the mechanic, there is allegedly NO FAULT with the car; yet when I get it back the faults are there!! - Am I losing my mind?????
1. Driver's Memory seat - loss of power, unable to do any form of adjustments.
2. Sunroof - elec. tilt/slide - opens fine, go to close it - slides to about an inch from the end and slides back out again!
3. Pongy smell from vents with a/c off and auto selected.
4. Seat belt warning on drivers side, takes 30 seconds to switch off after the passenger has left the car.
5. Xenons - loud audible grating heard from within the car, as the xenons swivel into place.
6. Key fob won't work - despite battery change!!
7. Lights illuminate automatically in daylight - on auto setting, but fail to illuminate in a dim tunnel.
8. Wipers work in dry weather automatically - on auto setting.
9. Parktronic sensors fail to work!!!
10. Gear got stuck in Park, had to call MB assyst, who forced it out, yet informed me that there is no problem (according to the computer) to the car. Since then, Tiptronic function lost, have to force gear stick into drive otherwise it stays in Neutral.
So 10 faults within a year - have I got a duff car??? What happened to the MB engineering that we hear about???
Garage is still unable to isolate the problems, let alone rectify them!!
All help appreciated
Tony
guydewdney
Tring, Herts
www.atct.co.uk
1) try pulng he fuse for the seats - r-st the computer.
2) DITTO
3) my cl did this until i cleaned the filter - on min its located on the n/s of the engine bay - lots of allen bolts. maybe the car has ben sitting for ages?
4) dunno
5) scary.
6) do the factor learn procedure. invlves zapping an turning on and off - RTFM... ;)
7) clean light sensor?
8)clean sensor - might be in same place as (7) - maybe not plugged in? - actually - snsor in same place as (6) - ake off plasic surround around rear view mirror - check its plugged in.
9) aaarrggghhh
10) hmmm
tke it back - say its not fit for purpose. sale of goods act etc etc. sounds like a lemon / friday afternoon special to me.
wagamama
Wombledon, UK
Hi Tony,
3. Has happened to me, after I picked up my car from the garage (had been sitting idle for the best of 2 months) and the climate control set to auto, and the car emmited a pongy smell.... I left the air con on permanently, and the smell cleared up itself within a couple of weeks.
8. No idea, but when I didn't close the bonnet hard enough, it didn't trip the sensors, so my wipers didn't work. Something to do with that or the actual rain sensors?
Status
