2002 s320cdi charcoal filter
123singlemalt
tynemouth, tyne & wear
2002 s class 320cdi, 2001 nissan x trail, 1980 honda cb900, 2002 honda pan european
I have exhaust fumes coming into the cabin, my local garage said it was probably the charcoal filter, when I picked the car up they said that there is no charcoal filter fitted, but changed the cabin filters, they were mingin, dont think they have ever been changed. The thing is I am still smelling exhaust fumes, not as bad but still there non the less. any ideas would be appreciated.
Mr Teddy Bear
Bristol Between Mill & Cutting
1998 W208 CLK 230K SPORT: MG F 1.8VVC: Flame Red Rover 216GTi
I believe and I'M SURE SOME ONE WILL correct me if wrong that the only charcoal filter forms part of the petrol tank breather/evapourative emmisions system and doesn't require changing acording to every wkshp manual I've ever looked in. Cheap filters fitted to the cabin venilation and heating system are more likely to be the culprit. Need to get em' fm Merc' dealer.:(
Cole@MBS
www.mbssouthampton.co.uk
Sounds like you have a injector seal leaking, hence the smell,can you hear a ticking noise on tick over??
123singlemalt
Hi, thanks, maybe there is a slight ticking noise, but not 100% certain, only had car for 3 weeks, so not sure that any engine noise is just typical merc noise, will have closer look/listen
