2003 C240 doesn't start (key is not turning) after a couple of simple repairs
Igor S
2003 C240 Base V6/2.6L
Hello,
I've replaced a multi-switch (turn signals, wipers, etc.) and faded LCD in the instrument cluster according to reliable instructions. However, the car is not starting anymore, it looks like some security system blocked ignition switch, I cannot turn the key. I tried to disconnect the battery and wait; it didn't solve the problem. Can it be reactivated with some professional scanner or another tool? Any other ways to undead the car?
Thanks in advance,
Igor
ajlsl600
france
would retrace yr previous simple repairs and look fuses. check you did not dislodge anything
Oldspanners
Normandy
C CLASS 2004 C180
Hello,
Thanks in advance,
Igor
Do you hear the ignition lock motor run when you insert the key, if not that's where to start.
I
Igor S
No, the car doesn't allow the key turning and doesn't react to it when I try to open/close doors remotely. Tried both keys with the same result.
Flyinspanner
Ruislip
Maybe you’ve slightly dislodged loom to the ignition switch?
I
Igor S
I will check this as well. I'm curious if I messed up wit SAS, could it disable the car? Does it need to be recalibrated after being removed? (It's the only way to replace the combination switch).
When you say you replaced the instrument cluster LCD how did you do it?
simmon01
Berkshire
E 270 CDI, E 220 CDI & C180 Estate E280 CDI
