2004 SLK 350 Heater/Blower problem!
nick3814
Hi folks, just registered on here, it seems like a good place ask about problems
My wife runs a 2004 SLK 350 with full AMG kit, its a lovely motor and hasn''t caused us any problems since owning it for the last two years however for the first time I have taken it off the road for the winter, I have it on an accuguard trickle charger to keep the battery fully charged and I''ve started it today and drove it a little to make sure everything is ok but the heater is not responding! The leds are lighting on the controls but theres no air being blown through, even with the dial turned right up theres no blower at all, I''ve checked fuses which seem ok so I wondered if anyone else had this problem and solved it!
Nick
Cole@MBS
www.mbssouthampton.co.uk
Hi Nick, thats a new fault for a 171, i will look up and see where the fuse is for the fan, welcome to the site Kev!
Fuse 29 for the blower
N
nick3814
Yeah I checked all the related fuses for the blower/ac and they are all fine. When you switch the ac on/off you can here things happening (relays etc) but no airflow. I've turned up the fan speed and everything else resulting in nothing! The week I took it off the road I know it was working as the fan had developed a bit of a squeak which went on and off depending on the speed setting, its not been on ever since the battery went flat when it was sat for a fortnight which is why I fitted the trickle charger, everything else works but the fan/blower!!
It looks as though a new fan motor is required
N
nick3814
Would it go just like that? The cars only got 10,000mls on it!
Sadly one never knows,,it is possible that the air intake box got blocked with leaves etc, and water filled up the box.
I had two new struts on my SL at 15k miles, have a word with MB direct and see what they say,, things do go wrong with electrics. If it was the fan regulator the fan normally runs at a slow speed only
N
nick3814
Thanks very much for your help I will look into this.
Cheers
N
nick3814
Is the motor easy to locate? I'm handy with a spanner as I run a couple of older Porsches myself but the SLK is a bit newer and I'm wondering where to start?
Is it possible to get something like a Haynes manual for the newer SLK's
Cheers
Nothing on the ruskie site for 171 cars,, but I should be able to print you off a how to change it paper
N
nick3814
Thanks for that, let me know what you come up with.
Cheers
N
nick3814
Hi, Malcolm did you manage to sort out a change it paper for this problem??
