2005 E55 amg Battery
littlewimp
gloucestershire
E 55 Amg
Hi All and a Happy New Year, have a new battery ready to fit but i cant seem to open the boot not even with the Key, so i'm hoping that there's a point other than in the Boot that i can connect a trickle charger, i know on other cars there's sometimes a live terminal under the Bonnet but cant seem to see anything.did think about using one of the 12 volt sockets but don't think they power up until cars running, any help would be great.
L
littlewimp
gloucestershire
E 55 Amg
Removed Passengers front carpet and not much under there, cant find anything under the Bonnet either. it is a late 2005Car not sure if that Makes a difference ?
Hi
Maybe we should concentrate on trying to get your boot open
So what’s happening with the key? Has the lock decided not to work through lack of use?
L
littlewimp
gloucestershire
E 55 Amg
Not Sure John, key goes is as normal and turns but its not operating anything. i've used it in the Past with no issues. going to take a look now.
L
littlewimp
gloucestershire
E 55 Amg
Managed to get a connection off the alternator so its taking a Charge, hopefully within a few hours i should be able to gain access to Boot , fit the new battery and address the key entry issue. Thanks
Spray some lube into the boot lock as well buddy
As Wighty, maybe first start with plus gas into the lock , slipping in with the key as it were. Might be the components are in the wrong position and need released. Try pressing down in the boot lid whilst doing it too. Proactive maintenance to make sure you can access the boot for situations like this...(ask me how I know!):)
Wearsafoxhat
Sunny Hampshire by the sea
Not sure what I’ve done with the pictures. The brass terminal is under a plastic cap with a big “positive” symbol on. The other brass post is identical to this one and above the suspension strut on the near side again.
www.ckinsurance.co.uk
