2005 s203 Key stuck in ignition switch
drone
350 slk, 200kW, 220CDI estate.
As above, the key is firmly stuck in the lock, I can remove the panel and get the neutral/park interlock cable end out when the key is free to remove.
I'm beginning to suspect either the steering column lock or the transmission gear indicator of having a fault but there are no codes. Has anyone experienced this issue that can offer suggestions.?
If fiddling with the interlock cable frees it there's your answer.
Check the cable is attached both ends and isn't broken. Also check it's correctly adjusted.
There won't be codes for a mechanical fault.
drone
drone
Sorted it, sold te car last monday.
davidwilson
Somerset
W209 CLK 320 convertible
A bit drastic!
(Do you usually flog them off when the3 ashtrays are full? :)
DSK
CLS 320 CDI, S350 Bluetec
Now get a Lexus and never look back!
Extreme but, I am on the brink of putting my w221 up. Can’t be dealing with these systems leaving you stranded and folks who refuse to run a diagnostics and perhaps a fix on the drive.
Simple and robust engineering cannot be beaten.
