Roger57
- May 6, 2015
- Location
- Lancashire
- 2011 E350, 2011 A180, 1973 VW 1303
My son has a 2006 A180 which had the battery replaced about 12 months ago. The battery is a proper Bosch item.
However, from fully charged, if the car isnt run the battery loses its charge over a period of about four-five days. I realise that some electrical systems remain active when the car is not in use, so I have checked the current drain when engine off and its about 0.2A. My wife has a 2011 A180 and I have checked the current drain on that one too by way of comparison; it is exactly the same and we have no problems with the car.
I have removed the fuse for the alarm system just in case that was the culprit but it made no difference.
Perhaps one of you auto-electrical guys out there can tell me if that sort of current drain is normal; as I said, our other A180 has exactly the same figure. I am beginning to suspect that the battery was faulty to start with (it should be under warranty). The battery was replaced by the AA. Can anyone assist please? I would be grateful if you could.....
Regards
Roger
Regards
Roger
