2006 S350 petrol Long brake pedal travel -ESP light on occasionally
widebodysec
Richmond North yorks.
AMG SEC wide body 5.6
Hi guys, having problem, brake pedal been bit soft and lot of travel. Bleed system, nope! New servo and master cylinder. Nope! Full pressure bleed again . No leaks no air either. Esp comes on and conputer diagnosed air or leak!! Any ideas.? Bit frustrating - Dave
What codes do you have in the esp module when the light comes on?
It takes a lot to get air out when the system has been emptied, including cycling the valves and a few esp related procedures, otherwise you have a soft pedal.
widebodysec
widebodysec
Here you go codes from scan
There is unfortunately still air in the system
  • Like
Reactions: DSK
widebodysec
widebodysec
But we thought not! Having read a different post it sounds so similar Maybe we will try once more then get it and put on star and “Cycle “ the abs. as you mentioned too. It’s annoying and but leakage for sure ! ‍
widebodysec
widebodysec
Hi well do e all the cycles etc but seems it is the abs block itself - swapping jt and the recycle and hoping for success as changed servo and nothing left really! ‍♂️
good luck. frustrating but hope you get there
widebodysec
widebodysec
Sorry i have no idea my
Mechanic sourced and fitted. Was original an original part. Bosch may been mentioned ! ‍♂️
