2008 SL63
Hotspur
Mercedes SL
2008 SL63 with 60K miles - thoughts on a potential purchase - pros - cons - things to watch for...i dont mind costs of upkeep but don't want something that is ofcourse cursed by design and forever requires attention... any experience / views
sl500amgsport
Essex
SL500 2014
At the end of the day it is an R230 with ABC suspension so will require constant attention, buy an R231 if you want a trouble free modern SL.
Sent from my SM-G988B using Tapatalk
sausage
SL
Lots and lots and lots of buying advice on SL R230. Probably best that you search rather than asking someone to retype out everything that has already been said many times.
Leaking roofs. Check seals. Check all switches work. Check condition. Check MOT history and SH match. It is a Mercedes, it will be better than most cars. Gearbox oil done at 5 years/70k miles.
It is an SL, it is complex and will require more ££ to look after than a C Class.
Timeandleisure
London
SL500 2003 R230, E400d 4MATIC Coupe 2021
Lovely cars and as above... I would just check the rubber/foam block in the boot under the liner for dampness and around roof seals and wheel arches for rust. You can use this to reduce asking costs, because it will be worth it!
sl500amgsport
Essex
SL500 2014
If you search the forum you will probably run a mile (I did and quickly moved on to R231 which has run trouble free for 4 years)....
SL63 Mark
The South
R231 SL63 AMG
sl500amgsport
Essex
SL500 2014
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
V6Matty
Newark, Nottinghamshire
At that age you might just be in headbolt issue territory, find the engine number out and see if it’s in the affected range, you may just be outside it
Conor
London, UK
To get the engine number, visit OpieOils.co.uk and they should provide it once you input the reg.. very useful.
Cipollini
Slovakia
w216 CL63 AMG 2008 w211 E270 CDI 2003
Not sure if it´s true or not, but my friend from MB dealer said that only about 3-5% of affected 63AMGs were really affected with headbolt issue and it´s more likely your car will suffer another issue than headbolts after this mileage.
V6Matty
The rate was likely higher than that but in reality possibly unknown.
The point I was making was that the OP should check to see if his was in the affected range, it may not fail but is a known week point and should be monitored
Cipollini
Slovakia
I agree with you that the rate should be higher, but who knows... Happy owners are much less likely to write on forums than owner with headbolt issue.
If OP will get a car in affected range there are only 2 options. Replace the headbolts or just drive and enjoy the car (like me :) )
www.W140.co.uk&www.r129.co
