willdudeuk
- Dec 7, 2022
- E320 CDI W211 OM642
My 2009 E320 W211 OM642.290 is having trouble starting (long crank). White smoke out of exhaust and smell of fuel.
Takes multiple attempts. Have to let it prime and wait 30 seconds then crank and eventually it starts.
Once warmed up it starts fine afterwards. It’s after leaving it overnight and coming back that the issue reoccurs.
Have scanned and get the following fault code on the Engine module:
2195 - Lambda sensor heating, upstream; signal line is interrupted / Permanent
Please find the scan before and after fault codes were cleared.
Only 1 permanent code comes back which is the one above (2195).
Appreciate your help.
Thank you
Thank you
