Replaced front discs, broke sensor
replaced sensor, lights wont go out
Mechanic plugged in to Snapon sureTrack diagnostic -
Fault codes are 4418 - speed signal implausible
4428 -L6/1 Left front rpm sensor- gap between sensor and rotor is tool large
Above has been rechecked etc and quality sensor has been used.
Also the offending sensor sends fluctuating signals at standstill when the other 3 are stable at zero.
Mechanic seems to think its the ABS pump? Im not so sure as why would it suddenly just give up
Suggesrtions please are much appreciated....its already cost me £225 and got nowhere
