2010 C350 blue efficiency rattle on cold start
clarkey2311
C350 CDI - 2011
Hi guys and apologies if this has been asked several times before but my search didn’t really return anything, on cold start I get a rattle under the bonnet for about 3 seconds then it’s gone ... only happens from cold never from warm ... any ideas ??
clarkey2311
clarkey2311
C350 CDI - 2011
  • #2
Nobody ???
Maybe timing chain ? , not sure if your model has a weakness in this area ?
bembo449
gainsborough , lincolnshire
id go for timing chain tensioner , any other car ive heard that noise , its always been the tensioner that's at fault
Avnt
Mexborough
Mercedes c350 cdi estate amg
Does it do it every time? Mine sometimes does it when weathers really cold seems to behave when weathers mild and a couple of goes in the glowplugs
Avnt
Mexborough
clarkey2311
clarkey2311
C350 CDI - 2011
No not every time, only when it’s really cold ... it doesn’t sound as bad as the one in the clip you attached but it does sound similar
Avnt
Mexborough
Do you give it a couple of goes on the glowplugs or just once?
clarkey2311
clarkey2311
C350 CDI - 2011
Only ever once but will give it two goes tomorrow morning and let you know if it’s still happening ... cheers for the tip Avnt
Avnt
Mexborough
Mine fired smooth this morning
clarkey2311
clarkey2311
C350 CDI - 2011
As did mine to be fair ... I’ve really only noticed it when it’s say below 5 degrees ... strange
Lots of them do it for 1-2 seconds, its relatively normal.
Thicker oil helps but I would stay inside MB spec.
If it rattles for as long as that video, then there is a problem.
clarkey2311
clarkey2311
C350 CDI - 2011
Good to know, thanks Alexanderfoti
It did it this morning at 6 degrees even after a double dose of glow plugs but as stated previously it’s two or three seconds then it’s gone
It's because the tensioner is oil pressure driven. Thinner oil drains down quicker overnight.
Pathfinder
Gourock
What difference would longer go on the glowplugs have?
Avnt
Mexborough
If its only happening when really cold worth a try
www.W140.co.uk&www.r129.co
