2012 e220 cdi blue efficiency sport
stu 123
e220 cdi
hello all
i have fault codes P0236 ,P0240, P0106 P0299
its going into limp mode
i know its most likely a sensor but where do i look do i change em all and hope i get the right one
or do any of you know an easier way
i am pretty good with engines but not electrics
i car was running really well and then just went into limp mode
its in a local garage but after 3 weeks of nothing being done i need to get it back and do it myself
or take to a better diagnostic garage .
any ideas will be greatfully recieved
stu
AndySlade
Tadley, Hampshire
C220 Diesel Estate, Sports Edition
I would say take to a reputable MB independent near you. They would probably know problem from the fault codes. May need the facilities of a Star test to reveal all. If you post where you are located/based, I am sure members will come up with suitable recommendations for indie.
Larkone
NW Essex
C219 CLS 320CDI 2008
Post you location and someone will find you a local indy.
As a preliminary check all of the hoses to make sure there is no leaks on the boost side - very hard to see some splits
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
hello all
stu
You could try changing the Map sensor ,as it's more than likely giving you all those codes , provided you've checked all air hoses for splits and are housed correctly.
