2012 merc e class 220cdi
David Johnson
E220cdi
Just had car in 97000 miles for new water pump .
Mechanic said timing belt very noisy when starting car
Car seems to be running fine
Its a taxi by the way should I panic or is it common .
Many thanks
D
David Johnson
E220cdi
  • #2
Timing chain I should of said
Hello and welcome
If it’s a taxi, why the “low” miles? What’s the MOT history show for the mileage?
If the duplex chain is noisy then it needs looking at.
D
David Johnson
E220cdi
I've had it 3 and a half years from 30000. Serviced twice a year
D
David Johnson
E220cdi
How urgent we talking . What I'm pondering is it worth getting fixed if need be or time to trade for another car ?
steveq
Dublin
2011 Merc S212 E220CDI Estate; Tesla Model 3; 1965 W113 Merc 230SL Pagoda
It isn't a duplex chain on the OM651 engine.
The urgency is dependent on how bad it is. You certainly don't want it to snap !!
If the gear cogs and tensioner are OK it is a matter of linking the new chain to the old and winding it on. There is still a good bit of dismantling and re-fitting to be done though but it isn't an engine out job.
Whether you do it or trade the car in is your decision. Did your mechanic give you an estimate of the cost involved?
D
David Johnson
E220cdi
850 quid for new chain
steveq
Dublin
I don't know how much it costs. There is a good bit of labour involved.
However, it would be worth getting a second quote from a MB specialist who has done the job before.
Where do you live buddy , so someone can recommend a good Merc independent who can hopefully shave a few hundred off that bill if it's just the chain
D
David Johnson
E220cdi
You didn't type anything buddy
moj91
Northamptonshire
W213 E400d-T, W204 C250CDI-T, W220 S320CDI (AMG Kit), W168 A170CDI, W210&W124 OM606...
My 250 cdi has rattled on start-up from around 20k when i bought it, no better/no worse 90k later. sometimes it is louder than others, but consistent.
