2012 S350 MAF sensor replacement
P
Pounder
Good morning I thought I would throw this out to the forum.
I have a faulty MAF sensor and have been told the whole intake unit must be replaced which is £700!
Has anyone managed to remove the individual sensors and do you have any feedback as to the correct procedure to do so?
Thank you in advance.
Did someone who has access to MB Star diagnostics , and a knowledge of MB’s tell you it need a new MAF ?
mioba
Nottingham and Köln
if assuming its a correct diagnosis, then no luck.
Mafs built into the batwing manifold.
Is this a petrol or diesel ? Because the diesels don’t usually have maf issues
P
Pounder
Hi yes it’s been diagnosed by a Merc Indi and my cheap OBD reader finds the same fault codes it’s the left MAF sensor.
P
Pounder
Yes that’s what I’ve been told and the cheapest full unit is £699!
mioba
Nottingham and Köln
First port of call is then to cleam them if you are handy, get the batwing off and give them a spray with carb cleaner/contacts cleaner - make sure its fully dry before you replace.
Get the rubber seals replaced at the same time while batwing is off.
Its not the best deign by MB, be careful as the plastic getts brittle at the turbo end / plastic and hot turbo not a good combi.
Good luck
John77
E200 Estate 2011, 2016 Smart Car
Good luck
Hi I have just changed my MAF on my 2005 E200 Estate. Yes different engine, different scenario, but I went through the MAF clean etc with a hope to not buy a new one, but it didn't make any difference and 2 days later engine light on and same fault. On this engine it is relatively easy, if you have the correct tools to remove the air filter etc, to get the maf off and I gave it a thorough clean with carb cleaner. I also tried a cheap version to replace it, but the car didn't like it, so I bought one from my local MB Dealer. Now all is fine. By the way the ones that you get from MB are not new, but remanufactured, unless you specify new and then they are a LOT more expensive. Personally I would just save all the agro and change the MAF for an MB original. Quicker and cheaper in the long run.
Any on eBay or a breakers like Dronsfields ?
ajlsl600
france
MAF.... now have to buy with intake at 699 !! Christ.might as well just leave ones cc with dealer,which I am sure will suit purchase them fine.cars and makers are going nuts.I changed mine on clk 10 yr ago ten min job and around 80 quid.what was wrong with that system ?
If al this was known at purchase would we still buy em ?
mioba
Nottingham and Köln
good points above. mercs dont like aftermarket.
merc are top draw with remanufactured parts. same warranty as new at much less the price.
