CodyRyan
- Jul 18, 2022
- Location
- Salt Lake City, Utah
- GL550/2013/4.7L 4663CC 285Cu. In. V8 GAS DOHC Turbocharged
This is my first time posting on a board like this so here goes. I have replaced the main battery, the aux battery, transmission pm, tested every fuse and relay, it seems to be electrical, when this occurs it faults out several items including the entire shifter mechanism, cruise lever, turn signal lever, distronic and a few others. The scanner shows several codes when this occurs. It was intermittent and you could turn the car off and back on several times and it would go away like it never happened. I am now looking at the shifting mechanism and clock spring area. I feel it has to be this component or the DSM. Any ideas?
