2013 Sprinter N/S Passenger indicator flashing twice the speed
bobjackson1988
2013 LWB Sprinter
Hello folks!
I'm new to the forum and have been struggling with the above problem for a while now. Its now MOT time and I know it will fail.
When the engine is running the passenger side indicators are going at double speed, drivers side is fine and at normal speed.
I've replace the complete passenger rear light unit inc bulb holder and checked to make sure all other bulbs are working properly.
Here is one I'm trying to get my head around - When the engine is off but key in the ignition the indicators both left and right work perfectly as they should. Blummin baffled.
Can anyone help?
Cheers & Kind Regards!
Bob
Altamar
South Wales
2015 SL400
All I know for certain is double speed indicators are almost always a sign that one of the indicator bulbs has blown or is not earthing properly. Are you absolutely certain all three bulbs on the passenger side are operating?
Flyinspanner
Ruislip
Probably the main indicator bulb blown, and it’s using the secondary.
EmilysDad
Bury Lancs
ML350
I'd only suggest what you seem to have already ie all bulbs (assuming normal filament bulbs) are clean and making good contact ... maybe any connector is unplugged & re-plugged in a few times to clean contacts and spraying with switch cleaner
mattkh
England
A160 W168 1999 1.6
Can you do one test for me please. Start the engine, turn the HAZARDS on, then go out and check if all four indicators (or six if you have one on the wing mirror) are working normally.
B
bobjackson1988
2013 LWB Sprinter
Morning,
Just checked with engine running and all 6 indicators are working when hazards switched on and at normal indicator speed
B
bobjackson1988
2013 LWB Sprinter
Main and secondary? I've checked this morning and with engine running all 6 indicators are working at correct speed when hazards are on?
B
bobjackson1988
2013 LWB Sprinter
Sure are
mattkh
England
A160 W168 1999 1.6
...... When the engine is off but key in the ignition the indicators both left and right work perfectly as they should. Bob
Thank you for doing the hazards test.
One more question. See your comment above. What position is the key in the ignition, 0 or 1 or 2.
B
bobjackson1988
2013 LWB Sprinter
Position 2. I have just tried in position 0, 1 & 2. Same results. Even with the engine running the hazards on all 6 indicators flash at normal speed.
Hope this helps with a solution!
mattkh
England
A160 W168 1999 1.6
I may be wrong, but I think it could be the indicator stalk.
I dont have a sprinter to check, but do you think you can remove only the shroud on the steering column to look inside. If you do, then please put up a picture of that area showing the wires going to the indicator stalk.
mattkh
England
A160 W168 1999 1.6
Been doing research. Forget about taking the shroud off the column.
As long as all the orange bulbs light up, the van should pass the MOT. The speed of the flashing is not an MOT failure, because it is doing its job to warn the other road users that the driver is turning in that direction.
One other thing I would like to know. When the flashing is at the fast speed, does the little arrow on the dash also flash at the fast speed? And what about the tik-tok tik-tok alarm, does that also speed up.
Thanks very much.
B
bobjackson1988
2013 LWB Sprinter
Thanks very much.
Good afternoon.
The flashing arrow works at the same speed as the indicators and yes, tik tok noise also sounds at the same rate as the flash
oigle
2003 ML270 sold but not forgotten. 2022 Kia EV6 GT Line RWD
Could one of the bulbs be an incorrect wattage? The indicator sender works on heat caused by current flow so if too high a current, it will turn off more quickly.
Ian.
EmilysDad
Bury Lancs
ML350
Ian.
I'm pretty sure there's a load more electrickery used these days ... I noticed that on my R Class when an indicator failed, though the tell tale on the dash & the audible click were double speed, the actual indicators still working on that side, still flashed normal speed
mattkh
England
A160 W168 1999 1.6
Ian.
Thanks.
What is another name for the indicator sender ?
Is it the indicator flash relay?
oigle
Thanks.
Yep. Couldn't remember the name. I'm talking old tech so could be different these days. Still worth a look at the bulbs.
clarkmichigan55b
sunny Surrey on a sunny day
Mercedes 208D T1 van 1989
I have just looked up the MOT testers manual on line with regards to the flashing times and is as follows.
4.4.4. Flashing frequency
Indicators must flash at between 60 and 120 times per minute. Semaphore type direction indicators do not need to flash.
Defect Category
(a) Rate of flashing not between 60 and 120 times per minute
Adrian.
