thanks for the reply, when you say correct diagnostic tool is there a difference? a local indy near me in S.London said they will connect the car up to the diagnostics.The only clue anyone would have is getting the car diagnosed by a competent merc indy with the correct diagnostic tool.
Very Near Croydon.Diagnostics tools vary alot and are then only as good as the operator.
I have a 15quid blutooth jobby that connects to my phone (which is good only for infotainment). Some other have icarsoft, there are alot of diags, the MB one being Star/Xentry.
Where are you located exactly, someone may have a recommendation of a good merc indy.
My wild guess...The aircon is making the fan work at full speed .. Some sensor senses that the fan may give up ...So the ECU displays the EML but only in amber.Highly unlikely to be Aircon related.
thanks for that, what fan are you referring to @mattkh I've just purchased the icarsoft handheld device, so i'll see what fault code it shows up, if that displays a fault code would that code lead me to a specific component or just general area?My wild guess...The aircon is making the fan work at full speed .. Some sensor senses that the fan may give up ...So the ECU displays the EML but only in amber.
i think i have to agree with you @Taffy7hfa my limited knowledge of motor vehicle engineering would suggest that the management system is unhappy when the aircon unit has been on for more than 30 minutes, a typical door - door journey in London. On both occasions this light has come on when the aircon unit was running. After the 1st code reset i've driven for nearly 2 months without any issues. As soon as i used the air con unit yesterday on my journey the light came back on! let's see what the readout says when my icarsoft unit arrives.In my experience an overheating engine doesn't usually switch on an engine management light.
the other code referred to a historic state, something to do with the Coolant, I recently had the car serviced at Mercedes so i don't really understand the historic code. I know that since 2013 there has been a change in coolant characteristics.What was the other code?
