gildeaa
- Oct 14, 2014
- Location
- Newtownards
- E Class 2004 320CDI W211
Hi, I hope someone can assist me with some guidance to this fault, it all started with the Comand system switching on and off, I changed the main battery as it was getting on a bit and thought that might be the problem, but alas no! I then tried disconnecting the earth from the battery for 30mins hoping that it would reset the system , still nothing happened, pulled the fuses for Comand from the front can and rear can for 30 mins in the hope of a reset and still nothing. I have removed the Comand unit and checked that the rear fuse is ok. The only thing happening is that the on/off button flashes.
I plugged Icarsoft MB2 in and I got this message Central Gateway codes P0610 stating "the coding of the control module is incorrect" U118300 "the diagnostic Can Network management is unstable" U116000 "A bus keepawake unit was detected"
further to that Instrument Cluster code U014787 "Communication with the telematics gateway has a malfunction, the message is missing".
Icarsoft is also telling me that the Comand unit checks out ok.
The car was due a service so i spoke to my local garage who has Star and asked him to have a look at it.
He said that Star checked out the system with no codes to reportand and that I need a new Comand unit which he will supply second hand, I declined this offer.
Any ideas would be welcome.
