2014 E300 Hybrid Estate
e300merc
I have an issue with the electrics, the dash lights start flashing on off and activating the externa lights. It started with the NTG system (command online) shutting down and turning back on. The light bulb symbol came up and the message about the tyre pressures appeared but they are fine. There is only one fault showing when plugged into the computer - the transmission fluid pressure. The car still drives as normal, so not sure what to do. Any ideas? Thank you
I'd be getting into the SAM modules looking for water ingress
