Julieoscar
- Mar 2, 2022
- 2016 200 d
Hi all I bought a used 2016 merc c class from a local merc dealer . It was two years old it had 15,000 miles on the clock good condition etc . After a matter of weeks the engine management light came on and the car wouldnt accelerate properly .Took it in, and the problem was cleared . a few months later had the engine fault again , had the nox sensor changed this was under warranty . A few months later same problem ,changed the other nox sensor .Then had the same problem a few months later this time I was told it could need two nox sensors changed together , or a temperature sensor or a new turbo . As it was getting more and more costly with no real answers I took it to a local merc garage the mechanic had the car for 4 weeks he changed lots of parts the fault light would clear and then when he drove it again it would reappear . Through a process of elimination he found it was the temperature sensor . That was changed and it worked really well for approx 4 months then the fault light came on again although not with the acceleration problems . Weve just put in another nox sensor which has cleared the fault but after a 5 minute drive the pick up was slow and the light came on again . the conclusion now is that when you accelerate oil is getting into the air and landing on the temp gauge which means it needs a new turbo . Both the independent garage and the mercedes garage think this could be a possible solution but arent 100% sure . In the meantime im left with a car that you cant drive on motorways etc as it has poor pick up , cant be sold as it has the engine management light on !
I could spend £4 or £5 k for a new turbo but would it work ???? I just wanted a few opinions and to know if anyone else has had similar problems . Im not very mechanical so could you keep any responses simple please . I dont know what to do for the best I dont know if I can spend £4k and be back to square one ,I dont have the money to spare and it would break my heart . What do you think ?
