2016 smart Twinnamic gearbox. Which fluid is correct
John77
E200 Estate 2011, 2009 SLK 200
Hi I am changing the Gearbox fluid on the wife's Smart car (Twinnamic). On my Eclass I use Fuche Titan AFT 4000, Dextron 3. Can I use the same on the Smart car?
Worth a check with "Opie Oils" forum sponsor and they give forum discount ;)
EmilysDad
Bury Lancs
ML350
your Smart uses a dual clutch transmission, so it's a manual gearbox with auto controls .... is the car old enough or gone far enough to need an oil change?
John77
Just bought it, so I change it as a matter of course, as there is no history of it being changed.
John77
Thank you. They say
Castrol TRANSMAX Manual FE 75W Fully Synthetic Transmission Fluid​
Febi Bilstein 75W Gearbox Oil / Manual Transmission Fluid GL-4 | 21829​
Motul Multi DCTF Synthetic Dual Clutch Transmission Fluid (Dry & Wet)​
