2017 glc rear diff fluid change
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
Hi / is the rear diff fluid change straight forward remove bottom bung ( is it Allen key ) then refill up to level of top bung. Also anyone know right fluid and how much needed for 2017 glc 250 amg , only 40000 mls but would like to change it if straightforward as just got gearbox done.
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
You remove the top bung first. Then the drain. Let it drain for a good while . You want as much of the new oil in as possible,not a mix of old n new.
I bought this for my 2017 e350.
mercmancdi
mercmancdi
onefortheroad
uk.
Is it 3.5 ltrs anyone know. Thanks
Seems alot tbh. It's usually just shy of 1 litre. Some upto 1.2 litres.
mercmancdi
mercmancdi
Have 2 ltrs of this Castrol 75 W 90 any reason this would not suit. It states axle fluid multi vehicle image.jpg
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
Sorry to jump in.
Mine is supposed to take 1.1L.
I have some old oil left, Can I get away with 1l of new good stuff as above and top up with a little old oil? Bearing in mind 1l will probably fill it.
onefortheroad
uk.
Sorry to jump in.
If it's the same brand and type yes. You can mix any really , it's just more beneficial to use as much new oil as you can.
mercmancdi
mercmancdi
Sorry to jump in.
Seems that be ok I know of some where the bottom bung was rung and would not come out but top fill bung came out and they sucked oil out as much as possible and topped up with new it’s better than not changed at all . But as said earlier by o p take top bung out first as if it won’t come you have no way of refilling.
Sorry to jump in.
Sneaky buddy :)
Tel: 020 8863 9233
