2019 E class cabriolet roof doesn’t operate
Kevin 61
2019 E300 Cabriolet
Only done 3,000 miles came to put roof up last week but got error message saying boot separater should be closed. I tried this several times but no luck!
Problem is that although car is still under warranty all main dealers are closed due to the Corana virus.
Is there anything I could try doing myself?
K
Kevin 61
2019 E300 Cabriolet
  • #2
Car is E300 Mercedes
Hello and welcome
There will be a micro switch in the left hand receiver that the boot separator closes down into. You need to make sure that the switch is being operated when you move the boot separator to the lower position.
It is possible to close the boor separator without contacting the micro switch. So try it with your finger or a screwdriver that the switch is working. Then close the boot separator again and try the roof again.
K
Kevin 61
2019 E300 Cabriolet
Thanks I’ll try that later when my son gets back
mioba
Nottingham and Köln
New car, I would call oit Mobilo, surely they are still working, The tech hoping they send a MB tech might be able to fix it for you.
K
Kevin 61
2019 E300 Cabriolet
Any pictures of w
Anyone got a picture of where micro switch is?
K
Kevin 61
2019 E300 Cabriolet
Hello and welcome
Any pictures of where micro switch is?
The boot separator goes up and down. When in the down position it clicks into a catch on the left and right of the boot. Inside the left catch is small lever linked to a micro switch.
Below is my SLK, yours will be similar.
mioba
Nottingham and Köln
A mobilo techie with STAR will tell you immediately whats wrong
Rotorhead500
Very South Devon
Used to have a C63...
Had the very similar on Mrs RH's old MINI convertibubble.
Rear parcel shelf / boot separator has warped ever so slightly over its 12 yrs... just enough that it doesn't depress the microswitch fully.
Took it out, gave it a gentle Italian remodelling, left it in hall overnight, upside down with a bit of weight in the right places, and.... Mavis is your uncle!
Mrs RH could disengage flaptronic as she could now get roof down!
Steveorider
E class 220 2011 mercedes
Hello and welcome
Hi I have a eclass 220 2011 cabriolet roof suddenly stopped working nothing at all, separator switch working any idea,s please. How can I take roof down manually plz
Steveorider
Plenty videos to put roof up none to take down
Steveorider
Anyone any idea what could be the fault on my 220 Eclass 2011 mercededes convertible roof won’t operate up or down, separator switch seems to work according to instruments on dash, really baffling me, how do I put roof down manually please
McDonald
Surrey
SL500 2004
My wife's Flaptronic has been jammed on for some time. Her microswitches are inaccessible. Don't offer suggestions, I've tried everything.
John Laidlaw
Wirral
Land Rover Discovery 4
Even the ratchet and lithium lubricant approach?
