Hi. The car is currently running on two cylinders. Cylinders 2 & 3 are not running. No spark or fuel. It does how ever, send the test pulse on both the injectors and spark plugs and then cuts out. I have tested the leads, spark plugs, injectors, coil packs (twin coil packs under inlet manifold). These all checked out fine. Sometimes, for no apparent reason, the car runs fine for a short period and then goes back to running on two cylinders again. Has anybody got any ideas? Its got the VDO ECU in the scuttle panel in the engine bay.
Please help!
Please help!
