I bought my 2002 W203 270CDI estate with the driver's wing repeater smashed. This earlier car had the type with the small bulbs in. I bought some LED conversion ones from eBay,
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350165543692&ssPageName=STRK:MEWNX:IT
These look great and were fine for a while but first the warning started coming up for repeater right check lamp, then now the left one is also doing the same, which is highly annoying. The repeaters at all times are working fully.
I even did away with the multiplugs and soldered the wires together in case of any voltage drop but the problem still persists.
I wondered, is there a way of disabling the lamp checking on the car for these repeaters? Or a way to desensitise it? Or could I maybe mount a 1/4w resistor in series to simulate greater load and hence make the car believe the bulb type is fitted? What rating would you recommend?
The seller seems reluctant to refund and thinks it is my car at fault, and as I said, I like the appearance.
Any recommendations gladly received.
