210 and CLK headlamps
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Are the headlamps the same on the CLK 208 and E class 210 part numbers dont tally on EPC but have the same remaing numbers 210 520 03 61 or 208 520 03 61
jib
I dont think so Jib, but I can check, the 208 has more in common with the 202
Alex M Grieve
Broom, Warwickshire
You might both be right:
"The CLK introduced a new market niche for Mercedes-Benz. Although the W208 used components from the E-Class (W210) and had a specification level higher than the E-Class, it was in fact based on the less expensive C-Class (W202) platform." (Wikipedia)
But there is no way the headlamps were from the W202 Malcolm - those were rectangular, n'est pas?
jibcl500
jibcl500
Cambridgeshire
CL500,ML55,SLK280
I think they are the same.
jib
The chances are the the lamps share the same fittings to some extent,but not all, hence the different part numbers, there are many parts on all the cars that have a full part number for another in the range, like a on a 202 that uses a 210 remote locking module, but in this case it has the full 210 part number in the 202 parts list
P_BELLY
I'm pretty sure the main lights are not the same. If you look closely the E Class lights are rounder whereas the CLK lights are more oval (vertically stretched). Not sure about the inner side lights though, they may be the same.
Alex M Grieve
Broom, Warwickshire
I fear you may be right - a case of nearly, but not quite.
SilverSaloon
w124/1994/om606
they are not interchangable - i looked into all this when i had my W208 clk
