210 estate fan on permanent. cant connect to diag
hmang
could you help me guys...
the engine fan has decide not to turn off on my e 220 cdi 2001 est.
the instrument cluster came up with a warning and put the car in limp mode.
coolant level is ok.
i cant even plug my diag in as it just keeps asking me to turn on the ign.and wont go any further
i could use some help with finding this "circuit 15 " problem regarding the diag connection.
thanks
This is a known fault for the petrol engines where water gets into the fuse box, but not listed on the diesel cars.
Circuit 15 is simple it comes from pin 4 of the direct injection N73 module, it goes to connector X18 cockpit wiring harness, and on to fuse 2 and 3 in the same box rated at 15 amp.
The fuse for the fan is f20 30amp
All of this is wired to the K40 SAM see if any water under it (take it out)
H
hmang
thanks malcolm
i'll try to locate all of that lot and have a prod.
this is one of those funny ones where it's only been back from the body shop for a week after new door,wings,tailgate,bonnet and a load of paint and i can't help wondering if it'scoincidental or whether they've disturbed or soaked something.
i appreciate your help
ta
phil
This is a known fault on the 202 but not so much on a 210. if the car was got wet under the bonnet, then any water near that SAM will stop all communication with everything else
H
hmang
every thing else seems to work malc
i just cant get the diag to recognize the ign on
and that fan staying on thing....maybe the two are connected..i don't know.
where should i look for the sam ?
H
hmang
it was a popped 7.5 A fuse in the front passenger side fuse block.
fan not on permanent
diag now connects
thanks malc
Thanks for the feedback, and i have noted that one :D
