230 ce v p relay
deanb34
Hello, a few months ago I was on here with an idle problem. The car did not want to idle, but if it did it was all over the place, but when I pulled the plug off the back of the rotary idle it would idle, a bit low but would keep going, as long as the car was warm. I tested the rotary idle and the spear one I have and they both seem to be fine. So I was told to test the voltage protection relay, which I finally got round to today. I have 12v on all 30 pins and all 87 pins, they are the ones I was told to test, but I put a tester on all the pins and I also have 12v on pin 15, but pin 31 has a large brown wire going to it and that has nothing. Can anyone help?
D
deanb34
  • #2
Two things I forgot, the car is a 1991. And the rotary idle has a two pin plug, and when I put a tester across them I got 10v.
