230 TE Sunroof
Status
Not open for further replies.
Malus
Hampshire
Can anyone give some advice on the following i have just purchased a 1990 230TE and the sunroof jamms when tilted up fully and needs a little tweat of the manual closer on the motor to free it. All other operations slide open/shut work fine. Its only when tilted it jamms any ideas its driving me potty.
Ta Malus
spanners
manchester
Adjusting sunroof clutch
The plastic nut that you turn to wind the sunroof manually, is just a cap which can be flicked off. Underneath it is a normal 17mm nut.
Tightening that nut tightens the clutch. Only tighten it a bit at a time then try it.
Status
